Cost of cancelling TNT Sports?
CAB68
Hello,  I stupidly took out a new contract with EE which expires on 12/3/27 after my BT contract was winding down.  Broadband is fine but I never watch TNT sports so it is useless to me so it's £20 a month down the drain.  What is the cost of removing TNT Sports from my contract?  Thank you.
CAB68
Finally sorted.  Received help via the excellent Gillian via email.  It seems re the "message us" option on the app, when I opened it my phone was opening it via a browser rather thyan the external app, and as the option is not available on the website version it wasn't showing up.  I have now made sure my phone opens the app externally and the "message us" option shows.  Gillian has sorted all my concerns so you can close this.  Thanks to all who helped, most appreciated.
11 REPLIES 11
Northerner
Hi @CAB68
You'll need to speak to EE CS on 150 about this account specific question.
Thanks, is there a live chat option as I am deaf?
Northerner
Hi @CAB68
Yes check your EE app under help.
Also please note:
Thank you
CAB68
Well I downloaded the relay app, made several calls to the relevant number and each time after about a minute it just says "call ended".  What a useless bit of kit!!
Ali_A
Hi @CAB68
Please have a look at Communication support | Accessibility Services | EE for support with using the Text Relay service.
You can also have a look at the Relay UK website for more.
Alternatively, as @Northerner  mentioned you can use the "Message us" feature in the EE app
Just open the app, tap Help in the bottom menu, and then select Message us.
Ali
Yeah have looked at all that thanks.  No-one picked up on any of the several calls I made, even the Relay "helpdesk" didn't pick up!  🙄  I have messaged EE via the "message us" feature but still awaiting a reply.  Seems my only option will be to pay off my contract and move to another provider that are better in dealing with the deaf.  BT were easier to contact to be honest as they had Live Chat.  Stupid of me to change to EE really.
Katie_J
Thanks for getting back to us @CAB68
I am sorry that you have experienced this when trying to connect with one of our agents to cancel TNT Sports from your broadband account.
When you log in to your account online and see TNT Sports in your add-ons is there an option there to cancel?
If the Relay service is still not working I'd recommend completing the contact form on their website.
Alternatively, they can also be contacted via email [email protected] and will be able to look into why you are unable to connect.
Katie
Thanks Katie.  On the EE website all it says re TNT Sports is "To change or manage your subscription call 0800 9566 000".  I'll await any reply to my message I sent, thank you.
