BBC1 Sound an vision out of sync - Day 2
Groucho2
Hi
Second day of sound & vision for BBC One being out of sync when selected from TV guide - ALL other channels are absolutely fine. BBC One is ok on the iPlayer.
I have done everything suggested - sound sync, resets, restarts etc but no success yet.
I note someone has similar problem, mentioned on Twitter/X
HELP!!!!!!!!
45 REPLIES 45
Thanks for that.  FYI it's still happening and the amount of being out of sync does seem to vary day by day.  Today isn't too bad, maybe 20ms, but some days it's up to half a second
Sorry answered on the previous post, instead of this one
Leanne_T
Hi there @Notroc
Thanks for coming back to us.
If this is still happening, it may be worth getting in touch with our TV tech guides to get this looked into further.
Let us know how you get on.
Sonnet2
Hi, been getting this very issue with the BBC Scotland channel the last week or so. Tried messing about with settings and factory resetting the box but this hasn’t fixed it. I haven’t noticed it on any other channels. I’m using the TV Box Pro.
Is anything being done to fix this? With the amount of people reporting this on other BBC channels it’s clearly a wider issue.
DarrenDev
EE Product Expert
We're awaiting a fix from Amazon for the encoding issue for BBC channels @Sonnet2.  In the meantime, we just need to restart the stream every time it happens - I'll request BBC Scotland is restarted this morning.
I've just been informed that BBC Scotland has now been restarted, so it should be fixed again now.  I've also been told that we have the patch, and it's being applied to a few channels at a time.  All channels should be patched by Friday, at which point this issue should disappear for good.
Thank you. Appreciate the quick response.
TONYY37
This last week have noticed this has got a lot worse. It only happens on bbc channels through the tv box. Seen a few 'fixes' online but nothing seems to work. Iplayer seems to be ok. Any ideas?
Ok so this the same problem  I have since my fiber upgrade - just bbc 1 out of sync - on both boxes the mini and the pro - new network re reset and recreated by open reach - seemed to work for a while now back after about a week - the problem happens over WiFi and when hardwired !
DarrenDev
EE Product Expert
@TONYY37 @ShaunFender I've made the encoding team aware, however they may not pick it up until tomorrow.  The known issues we experienced previously are sorted, so this could be something new.
