esim won’t activate
mp1013
Please help !!
New phone upgrade
transfer with esim went fine and mobile data was working BUT icloud transfer didn’t work so I had to reset the whole phone - obviously then lost the esim
trying to then redownload/won’t activate
went into the EE app and replaced esim to get a new QR code every time i try to scan this it now comes up with cannot download esim
can’t get any calls or texts in either phone
@mp1013  You’ll need to call customer support so they can actually the eSIM for you.  This will have to be tomorrow now as customer support is closed.
Hi Chris, that's not much of a solution.
I have a similar issue and have had no service since Xmas eve and even on my home wi Fi I cant call, text or use wi Fi calling.
I cat call customer support either, like the OP as I cannot get calls or texts.
You could download Skype and call the freephone number using it if you are unable to call using another phone, it should be free.
