Mobile Data not activated message
sparcuk
On to my next problem now I've finally solved the issue of getting my old Vodafone number transferred to my new EE sim.
I cannot use mobile data as it reports that 'Mobile Data not activated' even though it is activated in the Settings (iPhone XS). The phone is one I have brought over from Vodafone, but is unlocked.
@sparcuk   Can you go to
  1. Settings. General. . ...
  2. VPN & Device Management. . If unavailable, tap. Profiles. ...
  3. Tap the desired profile.  This might say Vodaphone
  4. Remove Profile. . If prompted, enter your passcode and then tap. Remove. ...
  5. Restart your iPhone.
Katie_J
Hi @sparcuk
It's great to here your number has now been ported over.
Have you ever been able to use data from your EE SIM?
Do calls and texts work OK?
Katie
sparcuk
Thank you! That worked. If only they included those instructions when you request PUK (given that someone requesting a PUK will come from another network).
Cheers!
@sparcuk   EE don’t use profiles so no need to know about them.     You might be coming from a different network but that doesn’t mean your device has a profile installed not all networks use them and you might of purchased a new device from elsewhere.     I see your point but it’s your device so it’s down to you to make sure it’s fully compatible even if that means deleting a profile that another network has installed on your device to make it compatible with that network.
