on 08-09-2024 02:49 PM
Hello everybody,
My sim card seemed to be somehow blocked. I am not able to use it for anything (sms, calls, internet).
My payment are uptodate.
I am actually abroad and complketely stuck.
My mobile phone is a Samsung Galaxy A54 5G.
Could someone help me out to reset it withour loosing any of my pics or saved infos?
Many thanks,
Nicolas
on 08-09-2024 05:27 PM
@NicoJS76 : Has your SIM worked at all while abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
