on 08-09-2024 05:06 PM
I am in Turkey and I have no phone signal and no data roaming which is the add on for my contract. How do I fix this as can’t make phone calls or use any data?
on 08-09-2024 05:14 PM
on 08-09-2024 05:18 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
