on 08-09-2024 12:13 AM
Im in usa will my phone work
Solved! Go to Solution.
on 08-09-2024 02:27 AM
@Richieruff : Depends on whether you carried out certain actions while in UK to allow it to roam.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
