on 25-10-2024 11:02 AM
Hello,
Ive come abroad and forgot to set up my roaming, i cant contact EE as i have no signal and cant call any one else can advise me what else i can do? Thanks
on 25-10-2024 11:10 AM
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 25-10-2024 11:12 AM
