on 25-10-2024 12:03 AM
I've paid for the £25 roaming pass as recommended by EE for my trip to USA. I was told I could use all my allowances as normal. Now I'm here I can't call or text. I have roaming etc on. What am I doing wrong?
Solved! Go to Solution.
on 25-10-2024 12:36 AM
@Jennbo1 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
