Unable to Roam in Spain
JHWright
I have the EU add on but still unable to connect to any network in Spain. Didn’t receive the Welcome to EE in Spain text either.
Tried turning off/on and toggling Aeroplane Mode but nothing. Cannot send any texts to 150 either.
Works fine when connected to WiFi
Unable to get through to Customer Services
Help?!
@JHWright : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
