Roaming problem in Canada
Hamarch
I went to Canada yesterday, my phone shows "SOS" only for my EE SIM. I didn't buy any roaming package before I left. I only need to receive calls and text in Canada, what should I do now?
Northerner
Hi @Hamarch
You'll need to activate roaming on your account first.
Use Skype over wifi and use the number in my signature to speak to EE CS.
