05-06-2025 10:32 PM
Hi, do I need to activate the roaming service or will it automatically switch on when I arrive abroad?
05-06-2025 11:01 PM
Yes, if you're on contract you'll need enable your roaming ability before leaving UK by texting ROAMING to 150. Aside from that you'll need to buy any roaming passes necessary to cover your roaming charges when you arrive at your destination.
Where you going?
05-06-2025 11:01 PM
Where you going?
06-06-2025 09:24 AM
Hi @Ingyli
Welcome to the community.
As @XRaySpeX mentioned you will need to activate roaming before you leave.
This will give you a break down on Roaming Costs
Hope you have a great time away.
Ritu
