06-06-2025 04:54 AM
Hi Community,
I made the mistake of swapping my mobile device within my home country, causing alot of Mobile Banking disruption. Old phone is formatted and my bank is trying to call me but I'm not on a roaming plan nor have an active Subscription. Any Ideas what I could subscribe to get an incoming security call.? Thank you so much.
06-06-2025 08:08 AM - edited 06-06-2025 08:37 AM
What do you mean by "swapping my mobile device within my home country"? Does this mean you're abroad currently?
Have you used your SIM abroad previously, did you receive a welcome text message on first arrival abroad? These are good evidence of roaming being enabled if so. In these cases, manually cycling through all available local networks often resolves issues - toggling flight mode can have the same effect.
If not...On PAYG, roaming is auto-enabled once your SIM is used in the UK first. On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK. Did you do this?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
06-06-2025 08:34 AM
@bristolian wrote:
If not...On PAYG, roaming is auto-enabled once your phone is used in the UK first.
In this case where phone is being swapped, shouldn't this read:
If not...On PAYG, roaming is auto-enabled once your SIM is used in the UK first?
06-06-2025 08:38 AM
Are you on PAYG (implied from "not have an active Subscription")? If so, you also need to have sufficient PAYG credit to cover the roaming charge for the incoming calls.
