Roaming in India
ashishrsingh
Hello,
I have been trying to use 7 days Roaming data pass in India for my both Monthly pay SIMs on my account. But I am not able to buy this add- on and old travel pass add-on is activated. Also automatic network selection connecting to VI network which is not working - both data or mobile service. A manual selection of network to Airtel does work.. Any help pls adding 7 days Roaming pass pls?
10 REPLIES 10
Christopher_G
Hi @ashishrsingh
Welcome to the community.
When you arrived in India, did you receive a 'welcome' message with a link to purchase an add-on? Is should be the one I linked below. If you're not able to add through that, can you let me know what error message you get, if you get one?
Add-on status checker >
I have been using this roaming services ( travel pass) for few years now. This time I wanted to use 7 days pass which is new offering from EE. I didn’t send ROAMING text to 150 before leaving UK.. however the welcome text I received isn’t opening. If I send ROAM to 150 now, it further ask GOING TO details etc. after providing all details.. still I am required to wait for a text. Nothing really happens there.. after 36 hours.. not sure how to go about it
Lesley_W
Thanks for the extra information @ashishrsingh
Did you try that link that @Christopher_G posted above?
Lesley
Hi Chris,
I am afraid the link isnt working for me.  HTTP Status 400 – Bad Request from laptop, but on my mobile I could the daily data allowance for Travel Data Pass.
The welcome link I received doesn't allow me a way to by 7 day pass.
Hi Lesley,
The link provided by Chris is only provide me current status of my Daily allowance of Travel Data Pass.
Lesley_W
Thanks for checking that @ashishrsingh
Is the current Travel Data Pass working and allowing the use of data off WiFi?
Lesley
Hi Lesley,
yes it does.
Ash
Lesley_W
Thanks @ashishrsingh
It may be the fact that you have an active add-on preventing the option of seeing the new ones. However, as you are already abroad, removing your current add-on is not guaranteed to refresh your roaming options and may leave you without an add-on at all. If your current option is working, I'd recommend sticking with that.
Lesley
