Roaming Zone 1 pass not working in Bangladesh
Shahnazazam
I bought the zone 1 pass to use in Bangladesh so that I can make calls and use the internet with my data. I bought the 7 day pass for £25.00 and I received a message from 150 to say that I can use straight away.  But unfortunately it isn't working. I have a spend cap of £50.00 and I have ensured that data roaming is on within my IPhone settings.
Can someone please help as I can't seem to get through to EE either on the phone.
10 REPLIES 10
Northerner
Hi @Shahnazazam
Did you activate roaming on your account.
Hi Northerner,
How do you do that? I thought I did. Would be great if you could let me know
Have you used your phone abroad previously, did you receive a welcome text message on first arrival abroad? These are good evidence of roaming being enabled if so. In these cases, manually cycling through all available local networks often resolves issues - toggling flight mode can have the same effect. The menu option for "data roaming" merely enables use of mobile data whilst already roaming.
On my EE app, it says that I'm set up to roam in any country. So not sure why it isn't working
Refer to the post immediately above your last one. The option to enable the free roaming facility isn't available on the EE app or website, it used to be - and these scenarios were far easier to resolve.
Post a screenshot of what you're seeing, if you think otherwise.
Hi Bristolian,
I did receive a welcome to bangladesh text message yesterday when I landed. So I'm unsure why it isn't working. Will try to call them.
No I don't think I text 150 to say 'roaming'. Maybe that could be a reason
In which case, your phone has a local network connection and roaming is therefore active.
What exactly isn't working in Bangladesh? Can you make & receive calls? Can you send text messages? Can you use mobile data?
Shahnazazam
I can't use my data to to go on the internet or use whatsapp, instagram etc. I can only use it when I'm connected to wifi
Shahnazazam
so I'm on the phone to EE on skype and typed my number and it said that my phone is able to roam abroad. I'm going to wait and see if I can speak to guide.
