Roaming in bangladesh
Monura_141
Hi I'm going on holiday in bangladesh can I able to use the phone there ?
1 ACCEPTED SOLUTION
Michael_D
Hi @Monura_141
We do have network agreements in Bangladesh, so you would be able to connect to a local network while you are there.
If you have a pay monthly contract, you need to text ROAMING to 150 before you go to make sure it is set up to work when you are away.
In terms of the costs, you can find details on our roaming charges and add-ons for Bangladesh by heading to our roaming page.
Michael
Michael_D
Hi @Monura_141
Michael
If you are on contract, you may use your usual UK allowances outside the EU with up to 50 GB data per billing month if you have more, when you buy the Zone 1 Pass for £5 / day or £25 / week. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/bangladesh.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
