Re: Error message received when calling some Uk and Cypriot numbers. Currently in Cy
Antonella007
Im in Greek Cypriot
Katie_J
Hello @Antonella007.
Welcome to the EE Community.
Did you activate roaming before leaving the UK?
This could be done by either giving us a call or texting ROAMING to 150.
Katie
