Using phone abroad
Bradley58
I’m I Greece on holiday and need my phone for work. I have text travel to 150 and told I have data roaming set up but unable to use my phone unless on wifi. I can’t phone EE and there seems no way of contacting. First time I’ve used my phone abroad since the forced switch from BT and this service is appalling.
Katie_J
Hello @Bradley58
Welcome to the community.
I hope you're having a great time in Greece.
I would love to see if I can help get your phone working for you.
When you arrived in Greece did you receive a welcome text?
Are you connected to a local network?
Katie
Yes, and text travel to 150. Our Cap is set at £0, but we can’t update this online or on the app as no facility and none of the numbers work.
Katie_J
Thanks for confirming @Bradley58
I have just checked the app and this can be updated by following these steps:
Manage > Scroll down to Settings > Spend Cap.
Please ensure you have your main line selected on your account if there is multiple numbers on your account.
Katie
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Data roaming is just a phone setting for enabling use of mobile data whilst already roaming.
@Bradley58 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
