14-09-2024 02:46 PM - last edited on 14-09-2024 03:30 PM by Peter_W
Hi there im in cypress on holiday my internet its not working
14-09-2024 03:41 PM
Hello @Danial4 ,
Welcome to the community,
Did you activate roaming on your account before going to Cyprus? You need only do this if on contract as pay as you go is automatically enabled.
If you did, have you tried disabling automatic network and done a manual search?
Have you rebooted your device?
Did you get the welcome message from EE?
14-09-2024 03:55 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
