No service while in the USA
Cooper121
I arrived in the US yesterday afternoon, once I landed I noticed it didn’t receive a welcome text message from EE and my phone wasn’t receiving any signal and was stuck in SOS. I purchased the roaming abroad add on but nothing is working. I’ve read I need to message 150 but I can not message what other was could I fix this issue? I’m here for 2 months and really need my phone
Northerner
Hi @Cooper121
You'll need to speak to EE CS on 150 and activate roaming on your account.
Use Skype over wifi and the number in my signature.
@Cooper121 : You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
