Maritime Roaming not working
bdg051
 I'm currently on a cruise and want to be able to use the 'Cellular at Sea' network for any emergency calls i May recieve. I have tried to connect to this network without any luck. I have texted 150 before i left and made sure worldwide roaming was enabled. Any help would be appreciated.
thanks
Katie_J
Hi @bdg051
Do you have access to Skype to call our customer care team?
I'd recommend contacting our technical care team who can complete a further diagnostics.
Katie
15 REPLIES 15
Katie_J
Hello @bdg051
Thanks for coming here.
Did you text ROAMING to 150?
If yes, did you receive a text confirming this was enabled?
Have you tried restarting your device?
Katie
bdg051
Hi Katie,
yes i did text 150 before leaving yesterday and received this text. I have tried manually selecting the Cellular at Sea network but that doesn't seem to be working either. Any help getting this resolved would be much appreciated.
Thanks.
Katie_J
Thanks for getting back to me @bdg051
When you manually search does it allow you to connect or do you get an error?
Katie
bdg051
Hi Katie,
when I select it. It carries on showing 'No Service' on my phone even after waiting about 5 - 10 mins. I checked on Cellular at Seas Website and it says EE do have a roaming agreement with them so I'm not sure why it is not working
Katie_J
Once you are connected to Maritime you should receive a welcome text @bdg051
What phone are you using?
Katie
bdg051
I'm using an iphone 15 pro. I will try manually selecting the network again but normally it does nothing and won't connect at all.
Katie_J
Do you get off the ship during your stay @bdg051?
Katie
bdg051
Hi Katie,
As you can see Ive selected 901 which is cellular at sea, however am i still getting no service showing next to the wifi symbol on my phone.
Katie_J
Hi @bdg051
Do you get off the ship at any point?
Are you aware if others can connect to this OK?
Do you have a spend cap on your EE account?
Katie
