14-10-2026 07:01 PM
Hi i recently landed in france and roaming isnt working. When I go onto my EE app to activate it it gives me a message saying "we are unable to switch your status please try again"
14-10-2026 10:02 PM
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
14-10-2026 09:23 PM - edited 14-10-2026 09:24 PM
@Karlos1872 If on contract did you text ROAMING to 150 before you left the UK ? Have you used this tariff before now when abroad? If you have, have you restarted the device? There is no option in the app to enable roaming.
Are you on contract or PAYG ?
14-10-2026 10:02 PM
