Apple Watch Roaming in the EU
goldenmew
When checking the EE app it tells me that I can use roaming on my Apple Watch that I have a plan with EE for. This however doesn’t seem to be working and checking previous posts here just now after arriving abroad it seems that EE did not used to support it. Since the EE app says it should work, is this now supported by EE? If not the app should be fixed as it said that it would work. If this is supported, how do I get this to work?
@goldenmew  You can not roam with the watch, the app is wrong.   There is also no add on to purchase that will allow roaming with a smart watch like there is with a phone/tablet
Here’s your contact summary for a watch tariff.  >HERE<
Schockwave
@goldenmew , it works with bluetooth by having your phone nearby.
