International calls are barred
D-9
Hi Leanne please help?? I have received the message international calls are barred. I’m in Portugal have roaming set up and sufficient spend cap but cannot phone home (UK)
@D-9 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
