Can I use my phone in Morocco
Falcons2512
Hi do I need to do anything in order to use my phone for internet, calls etc before travelling to Marrakesh?
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
You can view roaming costs & available add-ons, via https://ee.co.uk/help/help-new/roaming-costs
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/morocco.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
