Top up
Eddie313
Valued Contributor
Valued Contributor
No one has been able to help me to solve the issue yet even EE!!!
It’s been a long time I cannot top up my balance and I have tried everything what I have been told by the community, EE and other advisors.
Ali_A
@Eddie313
If trying all those methods continues to give you an error message, the best option will be to contact our Technical Support team in Customer Service who'll be able to raise a ticket for this to be investigated and corrected.
I can imagine it's not convenient having to obtain a voucher or visit the EE store each time. It's strange for this to have started over the last 3-4 months.
Ali
13 REPLIES 13
How long's "a long time"? Sounds like your PAYG SIM may have gone into hibernation due to non-use.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
Eddie313
Valued Contributor
Valued Contributor
Hey there,
Thanks for your answer. I have been using the sim card for roughly 2 years and I top up my balance each month. I have got another sim card which monthly there is no problem, the payment is being taken every month from the same bank card, however when it comes to my pay as you go sim card its been a nightmare over the last couple of month (3 or 4, even more)? Either I need to get a voucher to top up my balance or ask EE to help me out to do it themselves.
Sent from my iPhone
So, a top-up voucher works but  using your EE a/c or  Fast Top Up doesn't?
Eddie313
Valued Contributor
Valued Contributor
Spot on!
Sent from my iPhone
Then it's peculiar!
When did you last make a chargeable action other than topping-up?
Eddie313
Valued Contributor
Valued Contributor
Last month
Sent from my iPhone
Michael_D
Hi @Eddie313
Have you been able to try another card, if you have access to one? It just helps us to narrow down whether it is something on the account or if it is that particular card.
Michael
Eddie313
Valued Contributor
Valued Contributor
Hi Michael,
I have done 2 other cards as well, it says something is wrong. No matter what card you use it’s declined.
Sent from my iPhone
Rach_H
When you speak with the team are they able to process this for you @Eddie313?
Rach
