Re: Call barring
EUGENius1983
Hi...I cannot use my ee sim because the call barring is on,I'm on pay as you go,but I spent money on my sim ,the call barring password I didn't put so I don't know it I cannot use the sim please I need your help
20 REPLIES 20
Alex_M
Star Contributor
Star Contributor
Hi @EUGENius1983
Are you currently in the UK trying to make calls to other UK numbers?
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Hi Alex
No I'm not in uk,I'm in Europe and call baring asked me a password 4 digits
that I don't know to turn it off
Christopher_G
Try using 1111, @EUGENius1983
That's the default PIN, unless you've changed it previously.
Did you text ROAMING to 150 before you left the UK?
You may need to go into your My EE account and enable data roaming if not.
Thanks,
Alex
Hi
No I didn't text roaming and i don't kniw what to do
I cannot receive text call or make calls
Can you please help me?
Sent from Samsung Mobile
Sorry I just noticed that you mentioned you are on PAYG - so texting ROAMING isn't relevant.
Did you make a call in the UK before you left for Europe?
James_B
EE Community Manager
Hi @EUGENius1983,
Don't worry, roaming is activated by default on pay as you go accounts.
Where are you being asked for a PIN? In your phone's settings?
Yes James
In my phone setteing they asked me for pin
James_B
Hi @EUGENius1983,
Which phone are you using? Can you let me know which menu options you selected before being asked for a PIN?
