How do I contact ee for help with restore my number
Mohamedaldanaf
hello there,
My number is out of network please restore it , I need to restore it to use it login in important account , my number is still unavailable until now.
For some really important reason I really need to restore this phone number. I’m aware of I haven’t used this number for some time and I just added up some credits. Is there any way I can use this number again?
how can I buy it again or reactivate it?
pls I need your help , Really appreciate
Yours
Mohamed Eldanaf
Then you have really lost it! Any solution to your problem can only lie with this important site you want to login to & its ability to change contact phone nos.
7 REPLIES 7
@Mohamedaldanaf : Sounds like your PAYG SIM may have gone into hibernation due to non-use.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
Mohamedaldanaf
I lost the number more than a year ago, but I need it urgently. Please, I want a solution to my problem.
Mohamedaldanaf
I try all things but i fail so i need this number
pls how can i restore it ?
How many times have I got to tell you that you can't? You got yourself into this pickle by relying on a no. that you never used. You can't expect it to last for ever w/out paying anything.
Mohamedaldanaf
And how many time i tell you i need a perfect solution for my problem?
i need to restore my number or take sms code to change it for ever
The solution you are seeking - restoration of your disconnected number - cannot be offered.
Not every problem can be solved.
