Playstation Portal using iPhone Hotspot not working
GmanDugg
I recently purchased the PlayStation portal through EE, very excited to use away from my house. Its works very well when on my home Wi-Fi, and also when connected to Wi-Fi when away from home. Issue I have is it will not connect to my phones hotspot regardless of what I do.
This is terrible news, IS there ANY way I can get this to work through my iPhone 15 Pro hotspot using my EE data ?
Matt_124
Unfortunately on iPhone you are unable to edit your APN settings in order to see if that allows this to work.
Switching from the default IPV4V6 to IPV4 is usually the solution to this issue.
So currently There is  no way to get this to work on my iPhone ?
Northerner
Hi @GmanDugg
You can try via a VPN.
