Stock Enquiry
Jay6565
Can anyone tell me if the iphone 14 good as new in black is in stock? On the website its a big vague, says in stock but also low stock and when its gone its gone
10 REPLIES 10
Katie_J
Good afternoon @Jay6565,
Could you please confirm what memory size you are looking at?
Katie.
Jay6565
Not to worry, just had a dispatch email! 🙂
Katie_J
That's great to hear @Jay6565.
I hope you love your new phone.
Katie 🙂
Jay6565
Thanks 🙂
I was wondering with the good as new phones. While I still be able to order Applecare+ from Apple?
Christopher_G
I can't see anything from our side to suggest you can't, @Jay6565.
I'd recommend checking with Apple first though.
Jay6565
ok thanks. Unfortunately its turned up faulty!
Christopher_G
Sorry to hear that, @Jay6565.
What's happening with it?
Jay6565
I know these are supposed to be good as new but its obviously been returned as it has issues, not sure what has happened to all the checks that are supposed to happen before its sent out.
So all I have is a cable and a laptop on the screen, which means plug into your computer. I have done that and itunes says there is a fault and it needs to either restore or upgrade ios. I have tried both options and both options fail half way through with various codes.
So far had error code 5,9,2003 and some other one.
So now I have an iPhone 14 which is a brick basically!
Jay6565
Have an exchange phone coming tomorrow. Hopefully better luck with that one!
