on 07-12-2023 01:44 PM
What happens if I add a roaming abroad pass to my account then remove it then add it again in the same month . Would I be charged twice for that same month .
Solved! Go to Solution.
on 08-12-2023 09:06 AM
This could result in duplicate charges @Harry_toro.
If you are travelling twice in the same month I'd recommend cancelling this after your second trip.
Katie
on 07-12-2023 03:58 PM
Hi @Harry_toro
Welcome to the community.
If you're doing two trips within a month, it'll be worth keeping it on. If you cancel it, a charge is applied for the remainder of the 30 days of the add-on.
on 07-12-2023 09:35 PM
What if I add it on again , would I be charged again
Katie
on 08-12-2023 09:14 AM
Would I be charged twice for the same month ?
on 08-12-2023 12:19 PM
Hi @Harry_toro.
If you cancel during your monthly billing period you’ll be charged £25 for the full month, not just for the days you had the pass.
Katie
on 08-12-2023 06:26 PM
Will be charged £25 again for the same month if I add it on again
09-12-2023 09:20 AM - edited 09-12-2023 09:21 AM
on 09-12-2023 12:20 PM
If you don't cancel it until the following billing month you'll only be charged pro-rata for the 1st month but you will be charged the full £25 for the billing month in which you cancel.
