My BT/TNT add-on has stopped working
corky100
I get BT Sport's as a free add on and is enabled but has now stopped working and says I don't have an active subscription.
Any reason why it has stopped, as I was told there would be no change?
49 REPLIES 49
Hello James,
I cant seem to connect my old BT add on to the new TNT add on. I've
downloaded Discovery+ and created an account but it still asks me to buy a
package.
Even went through the process that was sent via email to access this but
when completed, it said "already activated".
Can you please help?
Christopher_G
Did you try and link the account here, @nfugger?
It's the right hand 'Activate discovery+' link.
Where exactly? Can you share the link please - not sure what you mean.
Christopher_G
Oops, I forgot to link it, @nfugger. Here you go: discovery+ on BT TV
nfugger
Ahh yes - I've tried that. No success, unfortunately.
Christopher_G
OK, thank you, @nfugger. That usually links it. Are you using the discovery+ app?
nfugger
I've created a discovery+ account - same login as BT. Still doesn't work (see attachment). Its asking me to set up a package even though I've got it set through EE. Screenshot 2023-11-30 at 14.32.41.pngScreenshot 2023-11-30 at 14.36.18.png
Christopher_G
OK, thanks @nfugger
If you speak to our technical support team, we'll be able to check your account from our side and hopefully get you set up fully.
can you not reach out to them and get this fixed? I've outlined the issue.
Thank you.
Christopher_G
This account is specific to your account, @nfugger. The team will need to pass security with you and look into what's causing the problem. If you give us a call on 150, they'll be able to look into it for you.
Hope you get sorted.
