on 30-11-2023 12:01 PM
Hello,
I have the following add-ons, but it's very misleading:
£2.29 per day for EU roaming - Variable - This add-on cannot be removed
Roam in EU - Free
If the roam in EU is reported as free, why it does ask me to pay if I select any EU country in the website?
This is really bad advertisement...
So, am I supposed to take the roam free add-on (or roaming pass) as everyone else?
30-11-2023 12:08 PM - edited 30-11-2023 12:33 PM
The former, £2.29 per day for EU roaming, is a billing add-on that charges you each day you use any of your UK allowances in the EU.
The latter, Roam in EU, is a permission to allow you to roam in the EU in the 1st place.
Unless you have the latter the former does not come into play & you can't be charged but you won't be able to roam.
The £25 pm Roam Abroad Pass is an alternative option to the former. You would still need the latter to be able to roam.
30-11-2023 02:00 PM - edited 30-11-2023 02:01 PM
Thanks, that helps, but it's not clear at all for users, plus, if there is no roam option, what happens? I don't get signal at all?
on 30-11-2023 02:13 PM
Put the billing add-ons to the side, and your phone needs permissions to connect to foreign networks.
If your phone has no EE coverage (by virtue of being abroad) and no permission to use foreign networks, you will get no coverage. That has obvious consequences for your phone's ability to use certain services - making & receiving calls, sending & receiving texts, and using mobile data.
on 30-11-2023 03:30 PM
Yes, if you have no Roam permission option, be it for EU or worldwide, you receive no signal from the overseas networks where you are & therefore cannot roam at all.
on 30-11-2023 04:05 PM
If I'm already outside UK and forgot to enable it, how can I do it from EE if I have no way to connect or even send an SMS??
(only on a public wifi I think)
Every phone has the chance to unlock roaming, but in this case, it's an option from the EE account...
on 30-11-2023 04:06 PM
Your best opportunity is to use a public WiFi-connection to use a web-calling app such as Skype - to then call EE CS on +44 800 0798586
