on 02-09-2022 08:12 AM
Hi. I've used EE Perks for quite a few years but I've just tried to use a new code (well several really) and none of them work. Tried ringing on 150 but never can through despite waiting for nearly an hour. They don't answer........any advice please. Thanks
on 02-09-2022 10:10 AM
Hi @FB1234,
Was the plan you were trying to purchase already discounted?
on 02-09-2022 11:24 AM
Hi James thanks. It wasn't discounted that I could see. I'm moving to a sim only plan that EE has suggested. £21 per month 25Gb.
on 02-09-2022 11:32 AM
on 02-09-2022 11:34 AM
24
on 02-09-2022 11:38 AM
Thanks @FB1234
That plan isn't discounted so you should be able to apply your code.
What error message do you see at checkout?
on 02-09-2022 11:59 AM
It says invalid code entered. I generated two others and the same message. I tried the codes on other plans to check and the same error.
on 02-09-2022 12:06 PM
I've sent you a private message @FB1234
Please check your inbox and get back to me with the requested details.
Thanks 🙂
on 26-09-2022 08:21 PM
Hi 👋, I am facing the same problem. What was the solution may I ask?
Thank you 🙏
on 27-09-2022 07:59 AM
Hi @Ankit.
Do you get an error message when trying to use a code?
Does this happen with more than one code?
Jon
