14-08-2023 01:22 PM
I get told I am eligible, then when I try to activate I get error WB402. Long live chat with BT and they couldn't help. Any ideas?
31-08-2023 01:09 PM
I am getting the same problem with WB402 error code, anyone found the solution?
31-08-2023 02:50 PM - edited 31-08-2023 02:51 PM
Hi @Cymru01
Do you have TNT Sports showing as an active add-on in your My EE?
If so, has this been active since before 18th July?
Do you get this error when you set up using this link Activate discovery+ (bt.com)?
31-08-2023 03:01 PM
I have BT sport & had a notification that I need to change to TNT which I am trying to do,
I click on the link it says
Good news!
You're eligible to access discovery+.
when I click on the link it says
Sorry, there's been a problem. Please try again.
Code: WB402
Request ID - 1693490435611:BWXzzQlPrk85Kj31BWQx_
31-08-2023 03:06 PM
31-08-2023 03:11 PM
Hi Leanne,
It’s helpful if this workaround solves the problem for others as it did for me, however is anyone looking into why this process isn’t working on some mobile devices?
31-08-2023 03:19 PM
I have tried on iPhone & Chromebook.
31-08-2023 03:29 PM
I have just tried it on my Samsung tv as well with no luck.
31-08-2023 03:29 PM
The set up process and any feedback is being monitored by the relevant team, thanks very much for helping @LiverpoolOne
31-08-2023 03:31 PM
31-08-2023 03:34 PM
I can sign in ok, just when going to activate discovery it gives error.
