itsbellaboo
It hasn't worked for me in Italy, Spain and now Czechia. It doesn't work for my daughter abroad either. Rip off.
@itsbellaboo : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
