06-07-2023 01:15 PM
Hi - Why does my iphone 14 plus sound robotic on wifi calls but fine on cellular and whatsapp ? I have this phone for my partner and a standard 14 for myself. The 14 is fine with all methods of calling.
Are there some settings to reset/toggle ?
I have 500MB BB (TalkTalk) with an EERO PRO Wifi6 mesh router. As I say the 14 works fine, no issues at all, the 14 Plus doesn't.
07-07-2023 11:53 AM
Hi @mrcb2023
If you have WiFi calling turned on, this is the only setting you should need.
Have you spoken to our tech gurus?
07-07-2023 12:56 PM
Aside from enabling 4G-calling & WiFi-calling, there's no setting here.
If you're comparing two different devices, that's another variable which may mean identifying the issue is tricky. Do you still have your old phone?
If you start a call on VoWiFi, and handover to VoLTE (4G-calling) mid-call (or vice-versa), does the sound audibly change?
