on 06-07-2023 01:15 PM
Hi - Why does my iphone 14 plus sound robotic on wifi calls but fine on cellular and whatsapp ? I have this phone for my partner and a standard 14 for myself. The 14 is fine with all methods of calling.
Are there some settings to reset/toggle ?
I have 500MB BB (TalkTalk) with an EERO PRO Wifi6 mesh router. As I say the 14 works fine, no issues at all, the 14 Plus doesn't.
on 06-07-2023 03:12 PM
Hi @mrcb2023
Thanks for coming here.
Does the same happen if you connect to a different WiFi network?
Does this affect incoming and outgoing calls?
Thanks.
Leanne 🙂
on 06-07-2023 03:15 PM
Hi @Leanne_T This happens on any wifi network and it affects both types of calls.
on 06-07-2023 03:29 PM
Thanks @mrcb2023
Could you try the SIM card in another phone to see if the same happens and to help us know if this is the phone or SIM?
Leanne 🙂
on 06-07-2023 03:32 PM
Hi @Leanne_T We have just swapped from a Pixel 6 to iPhone 14 Plus and everything was fine on the pixel.
on 06-07-2023 03:38 PM
Thanks @mrcb2023
In this case, please get in touch with our tech gurus on 150 and they will run through some troubleshooting with you to let you know what is needed to get this sorted 🙂
on 06-07-2023 03:41 PM
@Leanne_T OK many thanks we will contact them.
on 06-07-2023 03:49 PM
on 06-07-2023 06:09 PM
There may be 2 aspects to this, to check on.
1: Firstly, "calls" made through calling apps such as WhatsApp & Messenger are not carried through EE's network as calls, but as what they are - data traffic. EE's involvement here extends to providing your phone with an internet connection.
2: There shouldn't be any perceptible difference between VoWiFi calls & VoLTE calls, your post suggests this may be the case? If so - how long has this been a problem?
on 07-07-2023 10:13 AM
HI @bristolian - This has been an issue since we got the new phone a couple of months ago. Yes understood.
Yes there is a definite difference between cellular and wifi calls. Maybe the phone has an issue and there are some settings i can toggle to try new things out ? Pixel works fine, iPhone doesn't.
