ee number 150 not working
PuckOfPooksHill
Hi. I see several people have had issues with the stated ee number 150 not working. Restarting or switching the phone on and off did not work for me. When I was abroad, seeking assistance, I eventually found a chat feature. The queue for help is pretty long though. It took a few days before I got the assistance I needed. However, I notice that incoming messages from ee now have +49 in front of the number. Could there have been a change of location or ownership? Does +49150 work for other people?
It didn't work when I needed it. But never mind. The current problem seems resolved.
20 REPLIES 20
@PuckOfPooksHill   Is that 150 doesn’t work when abroad or when within the UK ?
 If abroad is that perhaps because roaming wasn’t enabled on the account so obviously you can not call 150 as it’s still a phone call when abroad and without roaming being enabled will not work.
Thanks. Roaming was enabled when I was abroad. However, the problem occurs
at home too.
Leanne_T
Hi @PuckOfPooksHill
Thanks for coming here.
What happens when you call 150?
Do you have the number saved in your contacts?
Leanne 🙂
Yes I do have the number saved in my contacts. When I try to use it, it
states Not a valid number, though I used it in the past.
Any messages which come from EE now have +49 in front of the 150.
It thinks you're still in Germany. Try manually searching the Network Operators for EE.
Thanks. How do I do that?
Leanne_T
Morning @PuckOfPooksHill
Which phone are you using?
Speak soon 🙂
Fairphone 3.
Android system.
Leanne_T
Thanks @PuckOfPooksHill
Can you try going into Settings > More Networks > Mobile Networks > Network Operators > Select EE
Does this work for you?
