10-07-2023 07:48 AM
Hello, I am in Lithuania and I have no signal. I tried to connect manually to providers, but no luck. Without signal I can’t use my roaming. I’ve also rebooted my phone, tried to remove the Sim an place it back but nothing works. Are there any issues with EE in Lithuania? Any help would be appreciated
10-07-2023 08:17 AM
Hi @LauraFlis
Welcome to the community.
Is your SIM card a pay as you go SIM or pay monthly contract?
10-07-2023 08:18 AM
@LauraFlis are you on contract or pay-as-you-go or contract? Did you enable roaming if your on contract This is done by texting ROAMING to 150. If your on PAYG please see THIS
10-07-2023 09:42 AM
It’s pay monthly SIM
10-07-2023 09:43 AM
Hello Chris, it’s Pay Monthly and yes, I have enabled my roaming
10-07-2023 10:06 AM
Are you in an area where you know there is good coverage, @LauraFlis?
What actually happens when you search for available networks?
10-07-2023 04:21 PM
Yes, coverage is great. I’ve put my Sim to another persons phone and it is working just fine. Would you think it’s something to do with my phone? I have iPhone 11
10-07-2023 04:23 PM
Thats when I search manually
10-07-2023 04:30 PM
Which network showed when the SIM was in another phone? @LauraFlis
Can you try and connect to the same one?
10-07-2023 04:35 PM
How have you enabled roaming? By texting ROAMING to 150 while in UK is only way to do so.
