on 10-08-2022 11:10 AM
i am trying yo get to my voicemail bit it says it is not activated i tried 222 gets same
could it be that it is an old orange sim causing it i did try changing from the 100123 number to 222222 still have same tired OM ON OM OFF or VM Direct gets message its activated but isnt
cudtomer services cant seem to activate it
on 10-08-2022 12:56 PM
Hi @DrWho3000
Thanks for coming here.
What did our mobile care team advise when you called? Is this being looked into for you?
Leanne 🙂
on 11-08-2022 09:18 AM
CS couldnt find problem so send a new Sim which is EE old one I am sure is a old orange one
I did try changing the call divert number from 100123 to 222222
on 11-08-2022 09:31 AM
on 11-08-2022 11:08 AM
A Samsung Galaxy A 10s
on 11-08-2022 11:26 AM
Thanks @DrWho3000
When you hold down 1 to call voicemail, do you get the option to view the number for the voicemail?
on 11-08-2022 01:13 PM
pressing and holding 1 goes to 100123 i have troed dialing 222 and still get voicemail is not setup
on 12-08-2022 08:46 AM
Hi @DrWho3000,
If the new SIM hasn't resolved the issue, please get back in touch with Technical Support to let them know.
They'll be happy to help.
on 12-08-2022 02:00 PM
everything has gone bad since BT brought you out even my sons voicemail has gone he gets voicemail is undergoing maintainance even your new app is rubbish like a kid deasighned it
on 12-08-2022 02:43 PM
Sorry to hear this @DrWho3000
Please get back in touch with our Technical Support team to get this looked into further.
