Voice calls drop within 3 minutes when calling UK numbers abroad
Morris23
Just as in the title.
16 REPLIES 16
My replies that I sent to you go to Investigator... (this message was meant for bristolian)...
Your replies are to @bristolian . You are the only "Investigator" on here. It's your rank in this Community. Do you mean you yourself are getting sent emails with your replies? I think that's quite normal. It's how you've got your Notification Settings set-up probably as default. Those emails don't really matter. They are just Notifications of what's happening in the forum. It's what's in the actual thread that counts & there your replies are being made to @bristolian .
"I suggest speaking to our Mobile Care team so they can check everything from our side for you."
I spoke to a Technical Team on 150 (after hanging on the line for over 40 minutes...).
They suggested a SIM swap. I don't think it will help as a friend who lives nearby did that and it didn't change anything.
Anyway, I am still waiting for the new SIM (ordered a week ago, on 25th September)...
James_B
EE Community Manager
Replacement SIM cards are usually delivered within 2-5 working days so it should be with you soon @Morris23
Morris23
Well... I can't see the reason why SIM card should be faulty if most domestic connections are OK.
The other thing worth mentioning is poor coverage in my area. The signal of -117 dBm on average is very weak.
But EE will never admit it.
And in one of the biggest hospitals in Yorkshire, there is no EE coverage at all...
James_B
Don't hesitate to get back in touch with Technical Support if the SIM replacement doesn't resolve the issue @Morris23
EE have never, to my knowledge, referenced dBm levels publicly - it's not a measure that would have any meaning to most end-users who just want their phones to work.
Internal coverage mapping used for engineering & planning purposes is a lot more precise.
