Unable to make calls
MartineWylam
Hi there. I have the same issue. My phone won't let me make any calls, not even to 222 or 150
It keeps telling me I have dialled the wrong number
I have not
My son managed to call me, but your customer service did not manage to call me back (I used
another phone to call them).
The only solution I was given was: "buy another phone"
Is it really my phone that's the issue?
The phone worked fine until today. I haven't done anything to it
HI Katie. It was indeed my SIM card. The replacement one arrived and I have been able to make and get
phone calls ever since. Thanks for your support
13 REPLIES 13
Katie_J
Hi @MartineWylam
Thanks for coming here.
Have you been able to test your SIM in another device?
Katie
Yes, Katie, I have. The very same happened
I had an EE technician on the phone who's advised I change my SIM card
So I have ordered one.
However, I can text and receive texts
It's just calling that's impossible.
Could it still be my SIM CARD?
Katie_J
Hi @MartineWylam
If the same happened when you put your SIM into another device, this indicates possibly an issue with the SIM rather than your phone.
Would you please update me when you receive your new SIM?
Katie
Yes of course. It will take a few days though
what I find odd is the fact that it's not just that I cannot make a phone call, but that the error message tells me I dialled
the wrong number. Why would this be a SIM issue if I get this type of error message?
Katie_J
If I'm honest, I'm not to sure what could be causing this @MartineWylam
I'd absolutely recommend trying a replacement SIM and this will rule out any issues with the current SIM.
Should you need your SIM earlier, you can also pop by your local EE Store with photo ID and get one over the counter.
Katie
I have a mobility impairment
But I should receive the SIM within a few days, hopefully
What happens if this does not sort the problem out?
Katie_J
Yes, it should absolutely be with you soon @MartineWylam
If this does not sort the problem then this will need escalated and a ticket raised by technical support.
Katie 🙂
Hi Katie
I had a friend call me on the mobile in question. The message she got was "this number is no longer in service" or something like that. Does this sound like it could really be my SIM card? It sounds more like EE has disconnected my line. Please advise urgently as I cannot go on without a phone and I don't want to cancel my contract with you guys, but will have to if this is not sorted our quickly
Katie_J
Hello @MartineWylam
Our customer care team should be able to see if your account is closed.
If you would like this confirmed, I'd recommend getting back it touch.
I would love to be able to check this for you, however, I have no account access here on the community.
Katie
