Tunisia
Lynnclark
Going to Tunisia can I use my phone there ? Thanks
@Lynnclark : Yes, you may but it'll cost you.
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/tunisia.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
@Lynnclark  Yes you can.  If your are on contract  you need to activate roaming on your account and that’s done by texting ROAMING to 150 ( do it now it’s gifts nothing to have roaming activated ready to use abroad)
You also need to look at THIS to see what costs are going to be involved as you can not use your tariff allowance while there.
