02-12-2022 12:45 AM
Can somebody from EE please help there is an issue with network coverage in Thailand . I have tried everything to resolve the issue even tried sim in another phone . No good
need to resolve this issue ASAP
02-12-2022 02:16 AM
@0803 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
