Roaming in Thailand
Wiggy1406
I’ve landed in Bangkok and am not getting my data service. I did buy the roaming package.
any advice
mike
@Wiggy1406 : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
Thanks that all worked out
Bangkok here we come!!!!
Sent from my iPhone
