on 20-01-2023 08:01 AM
Hi, I've purchased the roaming pack before coming to Australia. I've done all right things to make it to work but it's not. Can someone help?
on 20-01-2023 08:53 AM
Hi @Snapper1975
Thanks for coming here.
Did you text ROAMING to 150 before travelling to make sure roaming was also set up with the roaming add-on?
Do you have signal showing?
What happens if you try and make a call?
Leanne 🙂
on 20-01-2023 08:58 AM
on 20-01-2023 09:02 AM
Hi @Snapper1975
Can you try and manually select a network in your phone settings, does this show any networks available?
on 20-01-2023 09:07 AM
on 20-01-2023 09:56 AM
Hi @Snapper1975
Do you hear a message when you try and make a call?
Can you receive calls and texts?
on 20-01-2023 12:30 PM
EE's part of the setup for international roaming is to enable two options on your account in the UK - "international roaming" & "call abroad & premium rate". It is these which enable your phone to connect to a local network in foreign countries, and then to make calls.
If those two requirements are inplace and you have issues, then it's often a problem with the local network you're connected to. Restarting your phone and/or manually selecting an alternative operator, will often resolve this.
on 20-01-2023 02:01 PM
@Snapper1975 wrote:
I'm even in WiFi and it still doesn't work.
Then there must be a fault with your device. Using WiFi is not roaming & has nowt to do with EE or its mobile network.
