Roaming fail
pd3417
Hi I'm roaming in Portugal and the service appears to be nonexistent.  I switch to my EE SIM and no data at all.  Can someone help?
Northerner
Hi @pd3417
Did you activate roaming on your account before leaving the UK.
If not you'll need to download Skype and use the number in my signature over WiFi to contact EE.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
