Roaming costs in Bosnia
Nadkhan
I would like to know how much it would cost me to roam data in Bosnia
1 ACCEPTED SOLUTION
Schockwave
Hello @Nadkhan ,
Welcome to the community,
I have checked here for you:
https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/bosniaherzegovina
Hope this helps.
Please if on contract, make sure you text ROAMING to 150 before going abroad.
If on pay as you go, you do not need to do so, as it is automatically enabled.
You need to have used your SIM card in the UK before going abroad, otherwise it will not work.
Rach_H
Hi @Nadkhan,
Welcome to the Community!
I'd recommend calling our Customer Care team on 150, and they can discuss the bundles available with you. Alternativley, if you go to Bosnia you will be prompted to buy an add on before you're able to get connected to the internet.
Rach
Schockwave
Hello @Nadkhan ,
Hope this helps.
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/bosniaherzegovina.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
