29-06-2022 11:07 PM
Sorry to ask you here but do you by any chance know if it's possible to activate data roaming abroad. Before leaving the uk, i forgot to text 150 and now i'm transiting in dubai and on my phone it shows 'no service'
Thanks so much!
29-06-2022 11:21 PM - edited 29-06-2022 11:22 PM
@Hongha99 : It might be possible by adjusting some settings of the your MyEE.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
29-06-2022 11:55 PM
Thank you so much! It’s really helpful! I have tried but it still shows no service. I’m just abit worried as my uk mobile phone number is used as a verification/authentication for my work email. I will try your suggestions too. Fingers crossed it will work!!
29-06-2022 11:58 PM
@XRaySpeX i just checked and both data roaming and call abroad options are blocked and it says EE are not able to make these changes at the moment. Do you think that contacting the agency via online chat would solve this? Thank you so much!
30-06-2022 02:42 AM
Call CS over Skype as I suggested. Peeps overseas keep telling me they can't see Live Chat from there.
